Coolizi Cooling Ace Review &
Price: Ultimate Solution for Hot Days
Hot weather can make life uncomfortable, especially when you're trying to
stay cool at home, work, or while traveling. That’s where the Coolizi
Cooling Ace comes in. It's a compact, portable, and powerful cooling device
designed to provide instant relief from heat. Whether you're indoors or
outdoors, this product helps you stay cool and refreshed.
about Coolizi Cooling Ace
– how it works, its features, benefits,
usage, customer experiences, and much more.
What is Coolizi Cooling Ace?
Coolizi Cooling Ace
is a portable personal air cooler designed to help you stay cool
and refreshed during hot weather. It uses evaporative cooling technology,
where water is used to cool the air naturally without relying on harmful
chemicals or heavy machinery.
Unlike traditional air conditioners, Coolizi Cooling Ace is compact,
lightweight, and energy-efficient. It’s perfect for small spaces like
bedrooms, offices, kitchens, or for use during travel and outdoor activities.
The device comes with a built-in water tank, and once filled, it can
deliver a continuous flow of cool, humidified air for several hours.
It features multiple fan speeds, quiet operation, and is
powered via USB or a rechargeable battery, making it easy to use anywhere. You
can also add ice water for extra cooling or a few drops of essential oil for a
refreshing aroma.
Overall, Coolizi Cooling Ace offers a convenient, affordable, and
eco-friendly way to beat the heat, especially when you need quick relief in
your personal space.
Key Features of Coolizi Cooling Ace
1. Portable and Lightweight
It is small enough to carry anywhere – to your bedroom, office, kitchen,
or even outside. You can even take it on a camping trip.
2. Quick Cooling
Coolizi Cooling Ace cools down your personal space in just a few minutes.
You’ll feel a fresh breeze almost instantly after switching it on.
3. Easy to Use
No complicated settings. Just fill the water tank, plug it in or use USB
power, and turn it on. It’s as simple as that.
4. Multiple Fan Speeds
It usually comes with 3 speed options – low, medium, and high. You can
adjust it based on how hot it is or how strong a breeze you want.
5. Water Tank and Humidifier
The built-in water tank keeps the air moist and cool. It also works as a
mini humidifier, helping you breathe better in dry air.
6. Rechargeable and Cordless Options
Some versions come with rechargeable batteries, so you can use them even
without plugging them in.
7. Quiet Operation
Unlike traditional fans or ACs, Coolizi Cooling Ace is almost silent. You
can use it while sleeping, working, or studying.
8. Energy Efficient
Consumes very little power compared to ACs or large fans. Great for
saving on electricity bills.
How Does Coolizi Cooling Ace Work?
Coolizi Cooling Ace works using evaporative cooling technology,
a natural and energy-efficient method to cool the air around you. Here's how it
works in simple steps:
Step 1: Water Is Added
You fill the built-in tank with clean or cold water. Some people also add
ice cubes to make the air even cooler.
Step 2: Air Is Pulled In
The device has a small fan that pulls in warm air from the surroundings.
Step 3: Evaporation Process
Inside the cooler, the warm air passes through a moist cooling
filter soaked with water. As the hot air moves through this filter,
the water begins to evaporate.
Step 4: Cool Air Is Released
During evaporation, the heat from the air is absorbed, making the air
cooler. This cool, moist air is then blown out through the front vent.
Extra Benefit: Humidification
While cooling the air, the device also adds gentle moisture, making it
comfortable for your skin, throat, and nose.
In short, Coolizi Cooling Ace turns hot air into a refreshing breeze
using only water and a fan – no chemicals or harmful gases involved.
Why Choose Coolizi Cooling Ace Over
Traditional Cooling Methods?
Traditional ACs:
Expensive installation
High electricity consumption
Not portable
Regular Fans:
Only circulate air
Don’t actually cool the
temperature
Can be noisy
Coolizi Cooling Ace:
Easy to move and use
Cools the air instantly
Quiet, affordable, and
energy-efficient
Benefits of Using Coolizi Cooling Ace
1. Stay Comfortable Anywhere
Whether you're at your desk, in the kitchen, or sleeping in bed, Coolizi
keeps your space cool.
2. Safe for All Ages
It doesn’t use any harmful chemicals or gases. It’s safe for kids,
adults, and even pets.
3. Improves Sleep Quality
Sleeping in a cool environment can help you sleep better. Coolizi
provides a calm, quiet, and cool space for a good night’s rest.
4. Reduces Risk of Heat Stroke
High temperatures can be dangerous. This device helps regulate your body
temperature and prevent overheating.
5. Skin-Friendly
Its built-in humidifier helps avoid dry skin and throat issues during the
summer.
6. Eco-Friendly
No need for harmful refrigerants. It uses just water and air.
7. Low Maintenance
No complicated parts. Just refill water and clean the filter occasionally.
How to Use Coolizi Cooling Ace
Using Coolizi Cooling Ace is very simple:
Place it on a flat surface
Open the top water tank
Pour clean or ice water
Plug it in or turn on the battery
Adjust fan speed as per your need
Enjoy the cool air!
You can also add a few drops of essential oils for a soothing aroma.
Who Can Use Coolizi Cooling Ace?
Coolizi Cooling Ace is perfect for:
Students
who need a quiet and cool
environment to study
Office workers
working in hot or stuffy
cubicles
Elderly people
who are sensitive to heat
Fitness lovers
who exercise indoors
Campers and travelers
looking for portable cooling
Pet owners
who want to keep pets cool
Coolizi Cooling Ace is designed for everyone who wants to stay cool
and comfortable during hot weather. Its simple design and user-friendly
features make it suitable for people of all age groups and lifestyles.
Students
can use it while studying or sleeping, especially during exams when a
calm environment is important. Office workers can place it on their
desks to stay cool during long working hours. Elderly individuals, who
may be sensitive to high temperatures, can benefit from its gentle and safe
cooling.
It’s also ideal for homemakers working in the kitchen, where
temperatures can rise quickly. Fitness enthusiasts doing home workouts
can use it for post-exercise relaxation. Even pet owners can use it to
keep their furry friends cool and comfortable.
Coolizi Cooling Ace is also a great option for campers and travelers
since it’s portable and doesn’t need installation. Its quiet operation makes it
suitable for use in nurseries or bedrooms, ensuring a peaceful sleep.
In short, whether you're at home, work, or outdoors, Coolizi Cooling
Ace is the perfect personal cooling device for all.
Priya D. – Delhi
"I bought Coolizi Cooling Ace for my home office. It’s compact and
works amazingly well. I feel cool even during peak summer."
John M. – Cape Town
"This product saved me from the unbearable heat. I carry it to every
room. It’s silent and efficient!"
Aditi R. – Mumbai
"The best part is I can use it while sleeping. No noise at all, and
the cool air feels great."
Peter S. –
Australia
"Perfect for traveling! I used it during a road trip and it worked
great with a power bank."
Where to Buy Coolizi Cooling Ace
Coolizi Cooling Ace is available online on the official website and some
e-commerce platforms. It's better to buy from the official source to
ensure:
Original product
Warranty and customer support
Special discounts and bundles
Pricing Details
Coolizi Cooling Ace is affordably priced, especially when compared to air
conditioners. Here's an approximate pricing range:
1 Unit
– ₹2,499 to ₹3,499
2 Units
– ₹4,799 (discounted)
3 Units
– ₹6,999 (best value)
Note: Prices may vary slightly depending on offers, shipping location,
and taxes.
Tips to Get the Best Cooling Experience
Always use cold or ice water in
the tank
Clean the filter once every few
days
Keep it close to you (on a desk
or bedside table)
Use it in a closed space for
better cooling
Avoid placing it near direct
sunlight
How long does the water last?
Usually, the tank lasts for 6–8 hours depending on usage and fan speed.
Can I use ice cubes?
Yes, ice cubes or ice water enhance the cooling effect.
Does it work without being plugged in?
Yes, if you have the rechargeable battery version. It can also work with
a power bank via USB.
Is it noisy?
No. It’s designed to be very quiet, suitable even during sleep.
Can kids use it?
Yes. It’s safe, chemical-free, and doesn’t have exposed blades.
Coolizi Cooling Ace vs Other Mini Coolers
Feature
Coolizi Cooling Ace
Other Mini Coolers
Cooling Speed
Fast
Moderate
Power Usage
Low
Medium
Noise
Very Low
Moderate
Portability
High
Medium
Humidifier
Yes
Some
Ice Water Option
Yes
Not always
Price
Affordable
Varies
Is Coolizi Cooling Ace Worth It?
Yes. If you're looking for an affordable, portable, and effective way to
beat the heat, Coolizi Cooling Ace is a great choice. It’s
easy to use, safe for everyone, and can be used in many different situations.
It may not replace an air conditioner in large rooms, but for personal use,
it's a powerful little device that delivers excellent results.
Pros and Cons
✅ Pros:
Compact and lightweight
Instant cooling
Low power use
Quiet operation
Built-in humidifier
Easy to use
❌ Cons:
Limited to personal space (not for large rooms)
Needs regular water refill
Not a full air conditioner
Final Verdict
In a world where summers are getting hotter, having a reliable and efficient
cooling solution is more important than ever. Coolizi Cooling Ace
stands out as a practical and cost-effective choice for personal cooling. It’s
ideal for anyone who wants to stay cool at home, work, or on the move.
Whether you're trying to sleep better, work more comfortably, or just relax
during a hot day, Coolizi Cooling Ace has got you covered.
